Eggy Copter is being released today!
Mobile Gameplay
After a lot of development, testing and mobile work, Eggy Copter 1.0.0 is ready for release.
Eggy Copter is a complete endless flight arcade game built directly for XenForo, with configurable flight physics, progressive difficulty, power ups, achievements, challenges, leaderboards, player statistics, mobile landscape gameplay and server validated runs.
Launch price: $20
Eggy Copter is also included with an active Eggy All Access membership.
Extensive ACP Customisation
One of the biggest features of Eggy Copter is how much of the game can be controlled directly from the XenForo ACP.
Administrators are not locked into one fixed set of gameplay values.
General Game Controls
- Enable or disable Eggy Copter
- Change the displayed game title
- Allow or disable guest viewing
- Control access through XenForo permissions
Flight Physics
- Gravity strength
- Thrust strength
- Stabiliser gravity
- Stabiliser thrust
- Maximum vertical velocity
Speed Progression
- Starting horizontal speed
- Maximum horizontal speed
- Speed increase amount
- How frequently speed increases during a flight
Cave Difficulty
- Starting cave height
- Minimum cave height
- How frequently the cave becomes narrower
- How much the cave narrows each time
This allows communities to make Copter considerably easier or considerably more unforgiving without editing the game code.
Gameplay Boost Manager
The included power ups can also be configured individually.
- Shield
- Stabiliser
- Score Surge
- Ghost Flight
For each boost administrators can control:
- Name
- Description
- Enabled state
- Spawn weighting
- Minimum distance before it can appear
- Effect duration
- Display order
Challenge Manager
Administrators can create their own challenges directly from the ACP.
Supported challenge objectives include:
- Distance travelled
- Number of flights
- Boost collections
- Power Cell collections
- Score targets
- Best distance targets
- Distance without using boosts
Challenge scheduling can also be configured as:
- One time
- Daily
- Weekly
- Monthly
Administrators can set custom targets, Activity point rewards, start dates, end dates, enabled state and display order.
Achievement Manager
Achievements are also fully manageable from the ACP.
Administrators can configure:
- Achievement title
- Description
- Category
- Unlock requirement
- Unlock threshold
- Activity point reward
- Hidden achievement state
- Enabled state
- Display order
Achievement conditions include distance, score, flights, collections, boosts, close calls and other progression milestones.
Custom Helicopter Artwork
The default Copter artwork can be replaced directly through the ACP.
- Upload a custom helicopter sprite
- PNG support
- WebP support
- Animated GIF support
- Adjust rendered width
- Adjust rendered height
- Adjust horizontal positioning
- Adjust vertical positioning
- Restore the original artwork at any time
Custom Pickup Artwork
Custom artwork can also be supplied for:
- Power Cells
- Shield
- Stabiliser
- Score Surge
- Ghost Flight
Each pickup can have its own enabled state and dimensions.
Audio Manager
Eggy Copter contains its own configurable audio system.
- Enable or disable game audio globally
- Master volume control
- Up to 10 background music slots
- Individual volume control for each background track
- Custom movement audio
- Custom crash audio
- Custom pickup audio
- MP3 support
- OGG support
- WAV support
- Upload, replace or remove audio through the ACP
Runtime, Leaderboards and Validation
Administrators can additionally configure:
- Maximum flight duration
- Leaderboard result limit
- Replay validation
- Automatic run risk threshold
- Replay retention
Eggy Activity Hub Integration
Eggy Activity Hub integration is optional and configurable.
- Enable or disable Activity integration
- Set a Copter specific daily Activity point cap
- Configure the first flight Activity reward
- Award points through achievements and challenges
Copter continues to operate independently when Eggy Activity Hub is not installed.
Administration and Run Moderation
Eggy Copter includes administration tools for keeping track of game activity and submitted runs.
- Recent flight activity
- Validated run statistics
- Unique player statistics
- Longest flights
- Flagged runs
- Achievement unlock activity
- Challenge completion activity
- Player statistics
- Leaderboard administration
- Game statistics
- Activity award information
Individual runs can be inspected through the ACP, including their validation state and stored replay information.
Administrators can manually invalidate suspicious runs or revalidate stored runs when required.
Maintenance tools are also included for rebuilding progression data and pruning old replay data.
Gameplay
Eggy Copter uses fixed step flight physics with progressively increasing difficulty.
Players must keep the helicopter inside the cave while the game gradually increases horizontal speed and reduces the amount of available flying space.
The further you travel, the more demanding the run becomes.
Power Cells can be collected throughout a flight alongside four different gameplay boosts.
Shield
Absorbs a cave collision and gives the player a short recovery period.
Stabiliser
Temporarily softens the flight physics, making the helicopter easier to control.
Score Surge
Temporarily increases the score earned during the flight.
Ghost Flight
Temporarily allows the helicopter to pass through cave walls.
Achievements and Challenges
Eggy Copter 1.0.0 ships with 49 achievements.
These cover areas including:
- Distance
- Scores
- Number of flights
- Lifetime progression
- Boost collections
- Close calls
- Skill based milestones
The initial release also includes 45 challenges, covering timed, daily, weekly, monthly and repeatable objectives.
Competitive Leaderboards
Players can compete across multiple leaderboard periods.
- All time
- Today
- This week
- This month
Tracked statistics include:
- Best distance
- Total distance
- Average distance
- Longest flight
- Best score
- Total score
- Power Cells collected
- Boosts collected
- Total flight time
- Validated flights
- Crashes
- Close calls
Each player also receives their own Copter statistics and flight record.
Mobile Landscape Gameplay
Eggy Copter 1.0.0 includes a dedicated mobile gameplay experience.
When Copter is opened in portrait orientation, the player is prompted to rotate their device.
Once landscape orientation is detected, the game is ready to play.
Starting a flight enters a dedicated fullscreen gameplay mode so the available mobile screen space is focused on the game itself.
An Exit Game Mode control allows the player to return to the normal Copter page afterwards, where achievements, challenges, leaderboards and the rest of the interface remain available.
Desktop gameplay remains fully supported.
Server Validated Runs
Copter does not simply trust a distance or score submitted by the browser.
The game uses deterministic flight behaviour and seeded cave generation so submitted gameplay can be checked against stored run information.
Runs can be validated, flagged for review and inspected by administrators through the ACP.
XenForo Compatibility
Eggy Copter 1.0.0 requires XenForo 2.3.12 or newer.
Available today at a launch price of $20.
Also included with Eggy All Access membership.
