Guest Mode 1.7.5 introduces expanded compatibility and improvements to guest gameplay integration and the RPG Extensions Hub.
- Compatibility: Minimum requirements updated to XenForo 2.3.0+ and PHP 8.0.0+.
- Installation requirements: Removed strict Eggy RPG version dependencies for greater installation flexibility.
- URL compatibility: Updated guest gameplay actions to support both friendly and non-friendly XenForo URLs.
- Guest gameplay: Improved routing across character creation, movement, NPC interactions, combat, quests, inventory and trading.
- Extensions Hub: Updated the Guest Mode card to display a clean Installed status without version numbers.
- Interface consistency: Maintains consistent presentation alongside other RPG extensions.
- Expanded XenForo and PHP compatibility
- Updated installation requirements
- Friendly and non-friendly URL support
- Improved guest gameplay navigation
- Updated Extensions Hub presentation
- Simplified extension installation status
