Eggy Swarm: Node.js & PM2 Multiplayer Setup Guide
Eggy Swarm uses a Node.js realtime service to power multiplayer sessions between players.
The main Swarm game, Story Mode, challenges, achievements and other single-player features do not require Node.js. This guide is specifically for setting up realtime multiplayer.
For most installations, the recommended configuration is:
Node.js host: 127.0.0.1
Node.js port: 31338
Public WebSocket path: /swarm-realtime
The Node.js service remains private on the server while players connect through your normal website using the
/swarm-realtime WebSocket path.Requirements
Before starting, you will need:
- SSH access to your server
- Node.js installed
- npm installed
- PM2 installed
- Access to your web server or hosting control panel
- Eggy Swarm installed
- Multiplayer enabled in the Eggy Swarm ACP
Node.js 20 or newer is recommended.
1. Check Node.js and npm
Connect to your server through SSH and run:
Bash:
node -v
npm -v
You should see version numbers returned.
For example:
v20.x.x
10.x.x
If either
node or npm cannot be found, install Node.js before continuing.Your hosting provider may already provide a supported method for installing Node.js.
2. Find the Eggy Swarm realtime directory
Go to:
Admin control panel → Eggy Swarm → Multiplayer
Swarm displays the exact realtime service directory for your installation.
It will look similar to:
/var/www/vhosts/example.com/httpdocs/src/addons/Eggy/Swarm/Realtime
Use the directory displayed on your own server.
For example:
Bash:
cd /var/www/vhosts/example.com/httpdocs/src/addons/Eggy/Swarm/Realtime
Replace
example.com with your own domain/path.3. Install the Node.js dependencies
While inside the Swarm
Realtime directory, run:
Bash:
npm ci --omit=dev
This installs the production dependencies required by the bundled Eggy Swarm realtime service.
Once completed, check the supplied Node.js application:
Bash:
npm run check
There should be no JavaScript syntax errors.
4. Install PM2
PM2 keeps the Eggy Swarm realtime service running after you disconnect from SSH.
It can also restart the service automatically if required and restore it after a server reboot.
Install PM2 globally:
Bash:
npm install -g pm2
Confirm PM2 is installed:
Bash:
pm2 -v
A PM2 version number should be returned.
5. Configure Eggy Swarm multiplayer
Return to:
For a normal installation where XenForo and Node.js are running on the same server, use:
Enable multiplayer: Yes
Node.js host:
127.0.0.1
Node.js port:
31338
Swarm will also display:
/swarm-realtime
You should also see:
Realtime secret: Ready
Save the multiplayer settings.
6. About the realtime secret
Eggy Swarm generates a unique realtime secret for each installation.
You normally do not need to manually enter or copy this secret.
The bundled Node.js service reads the secret generated by Eggy Swarm from your XenForo installation.
If you use the Regenerate realtime secret option in the Swarm ACP, restart the realtime service afterwards:
Bash:
pm2 restart eggy-swarm-realtime
7. Start Eggy Swarm using PM2
Return to the Swarm realtime directory:
Bash:
Start the service:
Bash:
EGGY_SWARM_HOST=127.0.0.1 EGGY_SWARM_PORT=31338 pm2 start server.js --name eggy-swarm-realtime
Now check the PM2 process list:
Bash:
pm2 status
You should see:
eggy-swarm-realtime
with the status:
online
8. Test the Node.js service directly
Before configuring the public WebSocket proxy, make sure the Node.js service itself is responding correctly.
Run:
Bash:
curl -sS http://127.0.0.1:31338/health
A healthy Eggy Swarm realtime service should return a successful JSON response containing something similar to:
"ok":true
You can also test the connection directly from Eggy Swarm.
Go to:
Click:
Test realtime connection
A successful test should display:
Connected
and:
Realtime service responded successfully.
If this test fails, do not continue to the WebSocket proxy stage yet.
First make sure Node.js and PM2 are running correctly.
9. Configure the public WebSocket proxy
This is an important part of the setup.
Players do not connect directly to:
127.0.0.1:31338
That address should normally remain private.
Players connect through your website using:
/swarm-realtime
Your web server therefore needs to proxy:
https://yourdomain.com/swarm-realtime
to:
The connection flow is:
Player browser
Web server / reverse proxy
127.0.0.1:31338
10. Plesk / nginx setup
If your server uses Plesk with nginx, go to:
Websites & Domains → Your domain → Apache & nginx Settings
Find:
Additional nginx directives
Add:
NGINX:
location /swarm-realtime {
proxy_pass http://127.0.0.1:31338;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header Host $host;
proxy_read_timeout 86400;
proxy_send_timeout 86400;
Save/apply the configuration.
This allows WebSocket traffic arriving through
/swarm-realtime to reach the internal Eggy Swarm Node.js service.11. Other web servers
If you use Apache, LiteSpeed, nginx without Plesk, or another reverse proxy, configure the equivalent WebSocket proxy.
The required route is:
/swarm-realtime
127.0.0.1:31338
Your proxy must support WebSocket upgrade requests.
The important WebSocket headers are:
Upgrade
Connection
If you are unsure how to configure WebSocket proxying on your hosting setup, contact your hosting provider and ask them to proxy:
/swarm-realtime
to:
127.0.0.1:31338
with WebSocket support enabled.
12. Cloudflare users
Eggy Swarm can work through Cloudflare.
You should normally leave Node.js listening only on:
127.0.0.1:31338
Do not expose port
31338 publicly just because you use Cloudflare.The player's browser should connect through:
wss://yourdomain.com/swarm-realtime
The expected connection route is:
Player
Cloudflare
Your website
/swarm-realtime
127.0.0.1:31338
If the ACP connection test works but multiplayer does not, check that Cloudflare or another security service is not blocking WebSocket requests to:
/swarm-realtime
13. Make PM2 survive a server reboot
Once the realtime service is running correctly, save the PM2 process list:
Bash:
pm2 save
Then run:
Bash:
pm2 startup
PM2 will normally display another command specific to your operating system and server user.
Copy and run the command PM2 gives you.
Afterwards, save the process list again:
Bash:
pm2 save
This allows the Eggy Swarm realtime service to automatically return after a server reboot.
14. Final multiplayer test
Return to:
The connection status should show:
Connected
Now perform a proper multiplayer test using two separate XenForo accounts.
Ideally use two different browsers or devices.
Both players should:
- Open Eggy Swarm
- Enter Multiplayer
- Create or join the same multiplayer session
- Ready both players
- Launch the multiplayer session
- Confirm both players enter the same multiplayer game
- Confirm player movement and realtime game state are visible to both users
This final test is important.
The ACP connection test confirms XenForo can reach:
Actual multiplayer additionally confirms that the public:
/swarm-realtime
WebSocket proxy is working correctly for players.
15. Useful PM2 commands
Check the current Swarm realtime process:
Bash:
pm2 status
Restart Swarm realtime:
Bash:
Stop Swarm realtime:
Bash:
pm2 stop eggy-swarm-realtime
Start it again:
Bash:
pm2 start eggy-swarm-realtime
View recent logs without leaving a continuous log process running:
Bash:
pm2 logs eggy-swarm-realtime --lines 50 --nostream
Save the current PM2 processes:
Bash:
pm2 save
16. Regenerating the realtime secret
If you regenerate the realtime secret from:
restart the Node.js service afterwards:
Bash:
The realtime service will then load the new secret.
17. Changing the Node.js port
The port configured in Eggy Swarm and the port used by Node.js must match.
For example, if you change the ACP port to:
31339
the Node.js service must also use port
31339.You can recreate the PM2 process using:
Bash:
pm2 delete eggy-swarm-realtime
EGGY_SWARM_HOST=127.0.0.1 EGGY_SWARM_PORT=31339 pm2 start server.js --name eggy-swarm-realtime
pm2 save
Your reverse proxy must then also point to:
127.0.0.1:31339
The following three values must always agree:
- Eggy Swarm ACP Node.js port
- PM2 / Node.js service port
- WebSocket reverse proxy destination port
Troubleshooting
ACP shows Disconnected
First check PM2:
Bash:
pm2 status
Then test Node.js directly:
Bash:
If this fails, the problem is between XenForo and the local Node.js service.
Check the recent PM2 log:
Bash:
PM2 shows errored or stopped
Check the recent log:
Bash:
Check the following:
- Node.js is installed and working
- npm dependencies were successfully installed
- You started PM2 from the correct Swarm Realtime directory
- Port 31338 is available
- The Swarm realtime secret exists
- The realtime service has permission to read the required files
ACP shows Connected but multiplayer does not work
This is an important distinction.
If the ACP shows Connected, then XenForo can successfully communicate with:
However, players connect through:
/swarm-realtime
If the ACP connection test passes but actual multiplayer fails, the most likely area to check is the public WebSocket reverse proxy.
- The /swarm-realtime proxy exists
- The proxy points to the correct Node.js port
- WebSocket Upgrade headers are being forwarded
- Cloudflare is not blocking the WebSocket request
- Your firewall or security software is not interfering with WebSocket traffic
- Your domain has a valid HTTPS configuration
The health check works but players cannot join each other
A successful health check confirms that the Node.js process is running.
It does not automatically prove that browsers can reach the public WebSocket service.
Check the public path:
/swarm-realtime
and review your nginx, Apache, LiteSpeed or other reverse proxy configuration.
Port 31338 is already in use
Check what is listening on port
31338:
Bash:
ss -ltnp | grep ':31338'
If another process is already using the port, either stop the conflicting process or configure Eggy Swarm to use another available port.
Remember that all of the following must use the same port:
Checking PM2 logs
Use:
Bash:
Look for errors relating to:
- Port binding
- Missing Node.js dependencies
- Missing realtime secret
- File permissions
- Invalid environment variables
- Node.js startup errors
Restarting after an Eggy Swarm update
If the realtime Node.js files have changed after an Eggy Swarm update, reinstall the production dependencies and restart the realtime service.
Go to your Swarm realtime directory:
Bash:
Then run:
Bash:
npm ci --omit=dev
pm2 save
Multiplayer stopped after regenerating the secret
Restart the Swarm realtime service:
Bash:
Then return to:
and click:
Recommended configuration
For most installations there should be no reason to change the standard Eggy Swarm settings:
Node.js port: 31338
Keeping Node.js bound to
127.0.0.1 means the realtime service remains private and players access it through your normal secured website connection.Setup complete
Your Eggy Swarm realtime multiplayer setup is complete when:
- PM2 shows eggy-swarm-realtime as online
- http://127.0.0.1:31338/health responds successfully
- Eggy Swarm ACP shows Connected
- The /swarm-realtime WebSocket proxy is configured
- Two separate XenForo users can successfully enter the same multiplayer session
- Both players can see realtime movement and game state
If the ACP test shows Connected but actual multiplayer does not work, concentrate on the public WebSocket/reverse proxy configuration rather than repeatedly reinstalling Node.js.
